ericc04
I have a dashcam connected to the 12V socket, which has been frequently plugged in and unplugged because it doesn't fit perfectly. I suspect this caused the problem. After turning the ignition and attempting to start the engine, the fuel gauge behaves erratically, moving up and then dropping.
Car when to economic mod and on the third attempt, the clock reset and rotated, but then returned to normal when I locked the car. Also noticed that alarm button and lock button were flicking after the car is locked.
I want to know if this is a battery issue or if some other error has occurred.
The car starts just fine when jump-started.
