Hi guys , need some help here . I have purchased 2011 PEUGEOT RCZ 1598cc THP GT 6 Speed MANUAL PETROL 2 Doors Coupe . Car has only 57 000 miles on clock and other day it came up with warning light once started ( says engine failure ) then it disappeared . i took it to petrol station and on the way there it used to come up with red warning light stop and oil sight on dash in red .
took it back home , pugged OBD and said oil pressure to high. fine , changed oil pump solenoid valve , didn't helped still same issue , then changed oil pressure sensor . also same problem. if i drive slow and easy - no warning lights on , but once accelerate sharper or try to reach 70 miles per hour - it comes back again . should i try changing oil pump or it can be other issues here ??
would be much appreciated to get opinion of the guys who had similar issues . don't want to do guess work ..
