Foglights are not mandatory on a car, so they wont be on a MOT list of checks
Kinda...I believe I'm right in saying that "if fitted" they must be working. But working as in turn on/off, I doubt there's a test of the beam pattern or bulb type.jassyo06 said:Foglights are not mandatory on a car, so they wont be on a MOT list of checks
Fog lights are mounted low to cut underneath fog and have a wider beam pattern to pick out kerbs better in poor visibility. So they do help a little BUT they don't throw light very far ahead otherwise they'd reflect too much off the fog and actually worsen forward visibility.Abzynthe said:They only test if the fog lights work. I wouldnt worry about it as Fog lights are only really for others to see you in the dark. They dont do much for visibility
stevebasshead said:Kinda...I believe I'm right in saying that "if fitted" they must be working. But working as in turn on/off, I doubt there's a test of the beam pattern or bulb type.jassyo06 said:Foglights are not mandatory on a car, so they wont be on a MOT list of checks
Sent from my GT-N7000 using Tapatalk 4
Ian68 said:Abzynthe. What headlight bulbs do you have in ?
Abzynthe said:These are the fog lights I have.
http://www.ebay.co.uk/itm/271239485797? ... 1439.l2649
These are my headlights
Dipped
http://shop.rczperformance.com/Dipped-B ... BH7HID.htm
Main
http://shop.rczperformance.com/Main-Bea ... BH1HID.htm
dand87 said:Abzynthe said:These are the fog lights I have.
Dipped
Main
With the fog lights - the ones you have are 7.5w but the ones on RCZ perf website are 35w and I've seen others at different wattage. Does it matter what Wattage bulb is used?
Abzynthe said:I have no idea about watts, but that may be why they arent very bright then
RCZ-Performance said:Abzynthe said:I have no idea about watts, but that may be why they arent very bright then
That is my understanding too as I am no electrical engineer. The HID upgrades we sell are rated at 35W and are very bright. We are looking at some high power LED bulbs for the fog lights currently that might be a better solution for some. Still waiting for a direct replacement bulb with a better output.
A typical household incandescent light bulb has a power rating of 25 to 100 watts; a similar amount of light would be produced by fluorescent lamps at 5 to 30 watts, or LED lamps at 5 to 20 watts.
The wattage value is the amount of power the bulb draws from the electricity supply, which is given by voltage x current, or Volts x Amps.
Some percentage of that power is converted into light, and the rest into heat. In an ordinary incandescent bulb, most of the power is dissipated as heat, and a smaller fraction as light. In a fluorescent or energy-saving bulb, a much greater proportion of the power consumed is converted to light. For this reason an energy-saving bulb has a lower power rating than an incandescent bulb with the same light output.
Now who's Yoda? :idea:jassyo06 said:A halogen bulb rated at 35 watts will give off....a certain amount of lumens/light output, A 7 watt led bulb will give out the exact same amount of lumens/light output whatever the led is rated at multiply this by 5 to compare with a halogen bulb.Thats why they are more efficient and burn light at lower tempretures... in centigrade...lol
Also halogen bulbs are rated about 3500k max......... led bulbs start at around 4300k upwards to 8000k, xenon bulbs start at 4300k and go up 12000k
K= Kelvins= colour tempreture, Sunlight ie light from the sun...lol is rated at 4300k so the higher you go the less natural the light will become and the lower the luminosty
stevebasshead said:Now who's Yoda? :idea:jassyo06 said:A halogen bulb rated at 35 watts will give off....a certain amount of lumens/light output, A 7 watt led bulb will give out the exact same amount of lumens/light output whatever the led is rated at multiply this by 5 to compare with a halogen bulb.Thats why they are more efficient and burn light at lower tempretures... in centigrade...lol
