Fuel cap drain blocked ?
Just thought I'd post this little item up I washed the car & found the fuel pipe full of soapy water it has a tiny hole to drain out the residues & was completely blocked up with crap so cleaned out the tiny hole & water is draining away nicely its a similar situation with the drains in the door recesses in the wings these also get blocked up which I now always clean out with fresh water
One a similar theme does anyone know were the drain holes are under the spoiler? I have tried pushing a wire up from the boot lid drain holes ( I presume that is what they are but the wire is not visible under the spoiler.
I need to check that one out I would have assumed the water is drained into the boot lid outflows if it went anywhere
trev200
Dorset
Where is the tiny hole I can't find it.is it left top bottom right of the filler cap? Thanks
Open the fuel cap look down on the wing side from where your standing & you will see 2 small openings in the rubber seal if you can't see them they must be full of crap wash around the cap with a toothbrush to clear them out
