- Joined
- May 7, 2014
- Messages
- 3,217
- Reaction score
- 725
- Points
- 113
You might not when you find out how much it costs! :lol:
I have the same issue. Mine happened on the motorway at around 150kmh. Went into limp mode, with no acceleration. Engine Fault: Repair Needed light is on, the car starts normally, for about 3 seconds the RPM goes from normal (little below 1000) to around 500, with lots of vibration. Checked the OIL (fine), checked the coolant (fine). Getting it to a mechanic to check the error codes on OBD2. Hopefully, it won't be expensive, just bought the car a month ago.Hi guys,
I am new to the forum and I want to ask about the engine fault. I had a look through this thread, but it seems like there is no one clear answer to this. My car is 2011 peugeot rcz gt 200. I have a video of what was happening and I'll write down everything what was happening so far and if anyone would be happy to read it.
I only had the car for about 4 months and I had Ignition coil, oil, oil filters and spark plugs replaced. I had this error checked and my mechanic said it must be the ignition coil but it seems like it's not. I had the error checked, but I cannot remember what the error code was
The first time I had engine fault message was in the first month after I bought the car.
-It happened about 10-15 times over the next 2 months.
-Most of the time it happened at high revs or on the motorway at high speed.
-Sometimes the car went into the limp mode, sometimes it did not
-Sometimes the error was gone when I turned the engine off and on after few minutes, sometimes a day or two
-Sometimes the engine was working ok, sometimes it seemed like 1/4 of the engine was working ( like on the video) and it sounded like a tractor
-We could not find the fault and I had ignition coil replaced, but it did not help
-My mechanic suggested that if I get my fuel from the supermarket I should get fuel from BP instead as supermarket's fuel may be not good. After I started getting fuel from BP I did not have the error for over a month, so maybe there is something in this.
-Now when I thought this is fixed after I switched to a better fuel it happened again.
If you have any ideas what could be wrong, I would really appreciate your help, Thank You
VID_20191228_221325 - Streamable
Thank you. Car goes to the mechanic on Monday, will report back.P1340 Camshaft position sensor B circuit malfunction Multiple misfires has been known to interfere with Crankshaft position sensor causing timing issues
P1062 Variable Valve timing Bank 1 Limp home mode full stroke position not reached check the wiring at Vanos can relate to Engine control module fault
Yes, I looked at that as well. Hopefully, it's a sensor or HPFP. Then it's a fairly cheap repair. Anything else it's expensive as I was informed.Misfire on cylinder 4 is often associated with a failing HPFP also
Maybe I should have used "not as expensive" other than fairly cheap compared to the repairs on my previous car, where anything was upwards of 700€. HFPF should be around 400€ (at the Peugeot dealer here) and 50-100 should be work. So in my book, that fairly cheap compared to my previous car Although I still hope it's a faulty sensor as the error code suggests.I wouldn't say the HPFP is a cheap repair unless you buy a reconditioned pump from Ebay and fit it yourself. Perhaps repairs like this are cheaper in Slovenia? Cheers. Bruce.
Not sure if serious or sarcastic tbhWon’t matter- the fact that you will now be using 100 Octane fuel from now on gives you confidence that not only are you protecting the engine but it will drive better and slightly quicker!
It will mix without problem.
