vin100
Could anyone succesfull save the adressbook from the car?
DenisPegugeot
Poland
I pressed - but nothing, restart the system and do it all over again. Error immediately at startup when I inserted the flash drive. (Maybe first install cards from 16 and then try others? I installed 18 and 20 and 23 - same error
NF7
Slovenia
Are you using a Windows computer or Mac? You might also try another decompression software.
This issue indicates an issue with data integrity!
NF7
Slovenia
Try another, the same error( Maybe you have link for original maps 2016?
If you are using MAC, please try on a windows machine. MAC usually puts some hidden files into the root of the USB (which then results in the error).
Pol68
Bulgaria
Hello. I have a Peugeot 3008 with NG4 and N42.03 software, but the 2020-2 cards are not installed. Error 0x26 appears and everything starts over. I manage to install only 2022.0 maps but there is no Bulgaria there. I am asking for advice.
NF7
Slovenia
If you wish to Install Bulgaria, please install the Eastern European 2020-2 maps. This issue tells you that you have some issues in the folder structure.
Pol68
Bulgaria
NF7
Slovenia
Please check if you have any hidden files in the root of the USB stick. If you used the thumb drive before with any MAC device, there are some hidden files probably there.
Pol68
Bulgaria
There are no hidden files. Does it matter that the last file has the ending .PKG and not .MD5
NF7
Slovenia
Yes. It should be .md5 as this file checks and verifies the structure of the files. Have you renamed it yourself or was it like this?
NF7
Slovenia
That's how it was.
These are the downloaded Eastern Europe 2020 maps? I have not tested those. Can you rename the file to md5 and then open it as text? Does it show md5 hashes for all the files?
