DenisPegugeot
Poland
I managed to flash the maps 2023, avoided the 0x1BC error, just formatted it through Windows. Now the question: On the maps, Peugeot does not show the permitted speed on current roads? how can this be done? is it posible?
NF7
Slovenia
Not to my knowledge.
AlexDee
Italy
Denis, I always install maps from Mac, never had any problems. Format with Disk Utility, then use BlueHarvest to clean the USB stick. Stop.
  • Like
Reactions: NF7
vin100
Hello,
I updated the new 2023 maps while driving for chrismas.
The pronunciation of some cities is in a wrong language but it works.
Since a few days, I have the issue, that the unit restarts from alone.
I had this issue after an update 2 years ago and I downgraded to the 2015 maps.
I don't want to downgrade again and I make a factory reset and since I did that, the hole unit is corrupt.
It restarts automaticaly very very often, yesterday it was every 30 seconds! It su...s!!!
All the changes (colour, language, etc) won't be strored, so I have to do it everytime I start the car! It's awful!
I had a look in the system menu today but I don't know wich point could be significant.
Any idea? Factory reset again? HDD busted? Downgrade the maps?
The BSI-reset is so tricky, I don't dare to do it.
Thanks for helping!
NF7
Slovenia
Hello,
Thanks for helping!
Hm, I never had issues with unit restarting. This seems like HDD issue and the update was written on an area with bad sectors. I'd try a factory reset only.
Hello,
Thanks for helping!
If you still have a USB or SD memory connected, disconnect it!
It could be that the memory has errors and NG4 is very sensitive to that.
It happened to me, a USB memory with errors caused multiple hard resets, losing all configurations.
You could verify and correct errors by connecting it to the computer, also format it again, full format, not the quick one.
vin100
OK Thanks.
Yes I had a USB and a SD card (only music) connected while factory reset.
By updating the maps ans POI I only use a full formated USB or SD as discribe on page 1.
I will try a new factory reset without both.
vin100
Do you know if it's possible to defragment the HDD? Maybe through the USB port?
NF7
Slovenia
You have to remove the HDD to do that. It is also a bad idea, I would replace the HDD with a CF Card if you have such issues. LINK
vin100
Thanks, I know the link. Do you know or have a tutorial how to get all the unit out of the car?
AlexDee
Italy
New risk areas / radars ? Still stuck at the August file?
SixOfSpades
United Kingdom
Hi!
Updated my 2012 RCZ's firmware first try - cheers!
Just wanted to double check about the maps - is the EUROPE 2023-1 the right one for the UK? And everything's all working with Navigation (like postcodes etc.)?
Download's ticking away now, but I wanted to check before I potentially made a fool of myself.
Thanks!
NF7
Slovenia
Hi!
Thanks!
I did not have any issues with postcodes with 2023-1. It is catered to EUROPE WEST (so yes, UK included).
S-J
Netherlands
Hi i just have a question.
i just installed the maps and it seems the poi list is missing. when driving around the maps work fine and we seen poi icons but when going into the poi list itself there is nothing there.
any idea what it might be or do i need a seperate download for that.
